GeneMiller
- Joined
- Mar 24, 2009
- Messages
- 3,547
- Name
- gene miller
the reason the fresh water pump stopped yesterday is because the water transfer switch stopped putting out 12 v. It's a little over 9 without having the machine running. It does come up with it running but still won't run the pump. The other plugs all put out over 12 and will run it. I tested both pumps with the same results. I'm reading it at the actual place you plug into not at the switch. I had 12 gauge wire with 8' run to the pump. Used it less than an hour and the dang thing broke. I checked the pump and wires yesterday and both were cool to the touch. Ideas.
Gene
Gene
