870 minor electrical problem
the reason the fresh water pump stopped yesterday is because the water transfer switch stopped putting out 12 v. It's a little over 9 without having the machine running. It does come up with it running but still won't run the pump. The other plugs all put out over 12 and will run it. I tested both pumps with the same results. I'm reading it at the actual place you plug into not at the switch. I had 12 gauge wire with 8' run to the pump. Used it less than an hour and the dang thing broke. I checked the pump and wires yesterday and both were cool to the touch. Ideas.
Gene
Sapphire is an amazing company . Less than 5 minutes after posting I get a call. Everybody was off today but someone still called to let me know they would help out. Ill tackle it tomorrow, It was just to hot to work in the box. I'll start with the switch and make sure 12 v is passing through. I did a quick inspection and there is no plastic smell and I didn't see anything melted.
Gene
Sapphire
I believe we have the best team in the business. We are truly on a mission to be the most knowledgeable company in the cleaning business. Thanks again for supporting our brand(s).
DA
Reactions: Dan
I did a quick check to see if it was the ground wire. No luck. I don't have time until later to look deeper.
Gene
Less than 10 minutes with a meter to find the problem. Blown diode. The strange part is all voltages checked out with the switch on. I decided to test with the pump connected and that's when it showed. 000 voltage under load. You could see the little diode had a crack.
Thanks Scott and Sapphire for the help.
Gene
Scott Harlib is an outstanding diagnostician, and unlike most mechanical types, as a strong customer service commitment and a friendly, patient manner.
If it were up to my service manager we would only sell Sapphire machines.
Reactions: Lee Stockwell
Dan
Dan
I'm still doing the happy dance. First residential job I did last week I got a walk up and he said " that is one nice set-up you have". I agree, it's badass!!!
Dan
Dan
Might be able to see it at the show in Vegas.
