I always had to wrestle with the hoses, or have someone wrestle them. Found it exhausting. If I worked by myself I would spend over half the time messing with the hoses. Typical way is to pull the hoses down to the far end and start cleaning your way back, cleaning backwards, pulling the hoses back as you go.
This time, I pulled the hoses to the far end, cleaned the first 10ft or so, then turned around and cleaned forward, let the hoses pull in behind me.
With that and Bob Foster's suggestion to clean one set of stairs up and down at the end of the hall, and cleaning the treads with the big wand, made the cleaning a lot less tiring,
2 more buildings to go
