John Watson
- Joined
- Oct 7, 2006
- Messages
- 2,885
Today, for the first time, I ran a true 2 inch system from my waste tank including my in line filter to my wand.
I finally got rid of all the bottlenecks from the waste tank to the wand.
1 The thru tank fitting was pvc and reduced it down to 1 3/4 ID changed it to a 2 1/2 sweep el.
2 4 ft 2 1/2 OD rubber hose that coupled to 2in pvc fittings which also had an ID of 1 3/4 inches which coupled to my 2 inch cool cuff male adapter fitting was changed to 10 ft of 2 1/2 ID hose. Which now connects to my modified pool filter.
Modified pool filter, Using a saw cut off both male ends. On the large end I installed a 2 1/2 hose barb with a nut into a 3 in hole I drilled and sealed with loc tite plastic epoxy. On the cap end I drilled a 2 1/2 inch hole and installed a 2 inch cool cuff male adapter with a washer made from a 2 inch abs pipe fitting also utilizing the epoxy. Please note I had the use of a machine shop at my disposal for tools. I used a chop saw to cut off the ends and a drill press to drill my holes. to make sure the holes were centered for my hole saws I turned a couple of wooden plugs to center my pilot bit in.
My machine vac system cannot be used without this filter housing in place
so we just put a nylon sock in it!!!!! (In the SS filter)
I am not sure if it was just me, but I think I heard and felt a definite improvement in the air flow noise and suction from the hose before I coupled it to the wand on our job today.
Cost break down
$67.70 in line filter on sale at JonDon includes tax Normally $79
37.85 2 hole saws and 1 mandrel at Sears
4.30 Loc Tite Plastic Epoxy at Lowes
25.00 2 1/2hose barb with conduit nut
???? Male cool cuff adapter (Can't remember what I paid Joe)
$134.85 plus 2 hours of labor
Friends, There is this dummy friend of mine making and selling these things really really cheap. You need to talk to Greenie, This was a pain in the butt job that is best left to someone mass producing these for us.
Helen and I, We be sucking!!!
Now, We can tell our clients "More suck for the buck"
Cost break down
