About the Hydroforce Revolution
My following dot
D Luke
Derek
I would think it would still draw but it cuts your pressure by 75% +/-.
If you're only starting with 90 psi you will probably only end up with a trickle.
Yes. What I want to do is prespray, then insert a rinsing agent inline. Maybe on occasion a deodorizer like SaigerCide.
Acp
Bjorn Marshall
on paper it seems that having residual acid rinse in your solution line would effect your pre spray but it never does
J Scott W
Jeffrey Scott Warrington
The sprayer would still draw at 90 PSI but the dilution rate would be greatly altered.
As Lee suggests, you could use a bucket to figure out the dilution. But I think each home and even the same home at different times of day is likely to have different pressure from the tap. So, even the bucket would not give a result that could always be counted on.
Reactions: Old Coastie
I never had problems using a hydroforce with my bane at low pressure. Just adjust your strength as you go. Some jobs I water it down more than others. Just keep your rinse steady untill you find the right balance then you can adjust that too.
I like to add my deodorizers to the prespray for dwell time instead of as a rinse. I tried the rinse way for a few years with different products but the only deodorizer I found that kinda works as a rinse is odorcide.
