Jamesh921
So, how do you adjust your relief valve for optimal vac and lift?
I've read a couple discussions on this subject over the years, but it wasn't long before the technical jargon started getting WAAAYYYY over my small vocabulary.
So, I'll tell you what I did and what equipment I have, and you guys can tell me what I did wrong. And HOPEFULLY will be able to agree on how to tell me how to set it correctly.
Equipment:
Powermatic Legacy 2100
25 HP Kohler Engine
45 Roots Blower
What I did:
1) Started engine and set rpms at operating speed (about 3000 rpms - yea, I know specs say to run it around 2650, but I overdrive it - sue me).
2) Blocked off vacuum port completely.
3) Turned butterfly nut on vac relief valve until it started opening @ 15 HG.
That's it.
Is it now operating at the optimal operational setting? If not, tell me how to set it properly.
I know Mikey will say that the first thing I did wrong was to buy a Powermatic :roll: BUT, my PM rocks. shiteatinggrin So he can just HUSH IT!!! 8)
Thanks
Equipment:
25 HP Kohler Engine
45 Roots Blower
What I did:
That's it.
Thanks
