Pics?This valve comes pre-set from Butler with no adjustment necessary, but the previous owner must have been tampering with settings. Anyone know the procedure for adjustment?
This is not the pressure unloader, but the valve before inlet to pump on low pressure cold water inlet.
Pics?
This is the same type of valve they use on homes to adjust incoming water pressure. You just use the t handle to adjust. Not sure why the butlers have them but they were used on older trucks mounts to slightly starve the pump so that it would draw chemical. You probably don't need to do that today. Adjust it for aprox 50-70 psi and you should be okay.Site Map - The Butler Corporation
www.butlersystem.com
I think you can probably eliminate that valve from your system. I don't think it's necessary on modern systems. It's rare to find too much pressure from a city water supply.Thanks Fred. That is the valve. Yes I know to use the 'T' handle to adjust for psi, looking for info on the actual procedure.
The pump can be gravity fed from the fresh water tank or garden hose connection, so I would have to connect a psi guage after the valve to measure correctly.
Maybe someone could give me an idea as to where the factory setting is on their unit by measuring the exposed threads on the 'T' handle.
That's what I was thinking also. I would like to eliminate the pulsation dampener as it has water flowing out the top and add a longer bypass line to absorb any pulsing, much like the setup on my HydaCell in use on the AquaTech.I think you can probably eliminate that valve from your system. I don't think it's necessary on modern systems. It's rare to find too much pressure from a city water supply.
The pulsation dampener is good to keep. There is a specific pulse hose you can buy but I don't think it is as effective. I see new machines still using a pulsation dampener.That's what I was thinking also. I would like to eliminate the pulsation dampener as it has water flowing out the top and add a longer bypass line to absorb any pulsing, much like the setup on my HydaCell in use on the AquaTech.
not uncommon to get 150 psi static here, with some systems spiking way higher.......however in the country you may be surprised. A private system near here spiked so high it blew off icemaker water lines and plastic toilet feed lines.
Did you figure this out?Will do Monday.
Thanks guys
When I bought mine it was about 6 threads showing. Of course I've moved it now lol.No. Haven't had time yet.
Tanks for asking though
