Fred Homan
- Joined
- Oct 7, 2006
- Messages
- 1,142
Bob Savage said:I wonder why the builder of that APO says to not use it for water extraction (mentioned at the end of the video).
Me too :xBob Savage said:The reason I asked is the APO we use draws 1.3 amps, will pump against high lift, will keep up with extracting standing water, and will go for weeks with no attention required for it's filter. Are we talking apples to apples? will your APO run Against my Steamway pulling 15” of hg?
I would expect something costing over a grand to work better than what you described.
Yes, Mike, we are talking apples to apples. I use this same APO in our slide-in with a Roots #45 blower, and it pumps against 14" Hg.ACE said:Me too :xBob Savage said:The reason I asked is the APO we use draws 1.3 amps, will pump against high lift, will keep up with extracting standing water, and will go for weeks with no attention required for it's filter. Are we talking apples to apples? will your APO run Against my Steamway pulling 15” of hg?
Scott,NobleCarpetCleaners said:I used the exact pump and similar plumbing on my first homebuilt TM with the Prochem float switch in my waste tank. You need to keep your incoming waste water filtered. I chewed up a couple impellers when I failed a couple times to filter lint and debris. It worked great and I was running 15" of lift as well. Keep a couple impellers on hand. And yes it is the best kept secret for pump outs.
Duane Oxley said:One of the main things when selecting a pump is having one that can overcome vacuum. And it takes about 2 PSI to equal 1" Hg.
Lee Stockwell said:29.92" hg (full vacuum) = ~14.3 psi
Duane Oxley said:But you're not gonna get a pump out pump to work with 15 PSI. (I tried one that was a double- diaphragm back in 2000 and it simply wouldn't work.)
