Air hose for water
Charlie Lyman
Charlie Lyman
for those using air hoses for water supply, what size hose do u use and where do you get the fittings for the ends? Links and pictures would be super cool too.
Lowes. I've posted pix here 2010. Will look for them. Places like Lowe's have all the fitting needed.
glenboy
GLEN
Tom at modernistic sold me 105 ft of some durable rubber hose with some really nice ends criped on...
All poly hose works great in most cases except when it's bitter cold.
The rubber/poly mix or rubber is still pliable when freezing.
Don't store any hose with water in it. That's a PITA to thaw and ruins some hoses.
Reactions: glenboy
floorguy
Doug
3/8 works....tried the 1/4 but to small for any amount of volume at long distances......
I bought it from Harbor freight and got the rubber pvc hybrid
http://www.harborfreight.com/air-to...avy-duty-pvcrubber-hybrid-air-hose-60358.html
went with some fittings from the local hose place for QD, thinking it would be better then unscrewing anytime something happened......i only have it on the 1st 50', that way if i have to quickly unhook for some reason, i can
oh and for a reel, or to have an extra reel for extra hose.....CAN NOT BEAT IT
http://www.homedepot.com/p/Liberty-...vOebRahy2yzp8HFeSlRSMaAjtU8P8HAQ&gclsrc=aw.ds
Reactions: Lee Stockwell
handdi
Randy
You can go to a place that makes hoses they can fix ya right up
I think about a buck a foot last forever
D
dgardner
http://www.northerntool.com/shop/tools/product_200464315_200464315
When using these hoses, do they lay flat on sidewalk, or do they curl up?
My current heavy duty rubber water hose lays completely flat. Got to worry about running them across sidewalks here in S.F and potentially tripping someone.
Reactions: glenboy
glenboy
GLEN
The rubber hose I have lays flat...and in Michigan weather Cold it stays very flexible and supple
Reactions: ruff
