Air Powered Floor Scraper
Extra wide 4" blade makes short work of tiles and linoleum covered floors. 2200 blows per minute separates any glued floor coverings quickly.
Piston diameter: 1-1/8"; Air pressure: 90 PSI; Air consumption: 10 CFM; Air inlet: 1/4" NPT
Weight: 11-1/2 lbs.
ITEM 37073-7VGA
$99.99
We bought one of these today at Harbor Freight and used it on removing tile.
It works pretty good for only $99.00. Made the job much easier and it only needs 90 psi to drive it.
If you remove vinyl or tile or rubber backed carpet you might give it a try.
Al the guys that used it complained it was too short for them so we may take it see if we can have an extension made. But they did say it made the job easier and if it were taller it would work great.
Sticky
thanks for posting that....looks like it would make a hard job easier....i'm always game for working smarter and not harder....thanks again....definitly going to have to get one....
