tmiklethun
That's the whole question..
there is no easy way when they're bad ...hair gets weaved into the fabric ..
turbine vac with roll brush in conjunction with those peel-off sticky lint roller thingies works best
If you’re doing it as a part of HWE, mist then work the fabric in tight circular motion with a towel. Follow up with vacuum / extraction. You could get the same effect by misting with distilled water, circular agitation then vacuuming when dry. This method works great unless the hair has become part of the weave.
https://www.schticky.com/?refcode=1002&ot=tm
These work really well and no fooling around with refills. We also have the larger one for rugs.
