Any dealers here with a General TX1810 in stock?
Goes on the TCS Warrior. She's getting where she loses prime. I figure as cheap as they are may as well just replace it.
Losing prime could just be an air leak somewhere. I would check that first before replacing the pump. You might end up replacing the pump and still have the same problem.
Jim Williams
Jim Williams
Thanks, I'll check that out. It just occurred to me that I do have a short piece of hose with a plug in it where the injection system used to be hooked that could be sucking air.
Alot of times you can find pumps cheaper at a pressure washer site.
But they probably come with different seals.
Reactions: Jim Williams
