Mountain View Carpet Care
- Joined
- Apr 4, 2007
- Messages
- 1,085
Genesis 59 Pros cons?
How many hours do you have and what went wrong?
DevilDog said:The 52 HP Ford model was terrific, that is the model that I had you idiot. You already said mine had wayyyyyyyyyyyyyy more vac than what you had and I know the heat of my Genesis was probably 60 to 70 degrees hotter than anything you have had.
The Linton version had a lot of problems but was still a good machine...the issue is the people that installed Linton's....but that is for another discussion.
And learn to spell dude.
DevilDog
WJMorgan3 said:talked with a former Power Clean and White Magic distributor in Massachusetts. He said you'd need a shoehorn to fit the Genesis in a van. Said a box truck would be better choice, mainly because of the weight. If I recall he said it came with a 65 or 68 hp engine? He said they had some bugs but the most serious problems have been re-engineered and all worked out.
Damn!! Do you really need 70 horses to clean carpets?
WJMorgan3 said:I'm not trying to start a fight Tim, maybe playing devil's advocate a little... so guys with 32hp "lawn mowers", heat exchangers, 45 or 47 blower that are dual wanding, are hacks?
How can the El Diablo with a 24hp Honda, a 45 blower and a kunkle get 2.5 hour dry times? I know it's not a HX system, it's propane or kero. So all that extra horse power is going to the HX to make hot water? Seems like a waste.
Why are cleaners so dead-set against a separate propane/kero water heating systems? Is it that much more convenient to have a HX system over a little giant or similar? Guys are that concerned about the smell of Kerosene in their chick-magnet carpet cleaning vans that they'd rather purchase a machine with 44 extra horses to make hot water and use 3.5 gallons of gas an hour to do it? They must be practically filling their vans up every morning just to do a days worth of cleaning, especially if they are dual wanding? I don't know, I'm just asking..
