alazo1
The guy doesn't know. It has 914 hrs. It's a 4.8 but he doesn't know if it has the salsa. Would it say it in the front?.
thanks,
Albert
thanks,
Albert
TimP said:I've never heard of a knob for a salsa machine. And I own one.
The way you tell is if you have an exhaust blower heat exchanger. It should be on the floor board behind the drivers seat. You should be able to see water hoses go in and out of it.
Also if you only see heat at 200 or below after running for 15-20 minutes of cleaning then it's not working right. Cause with salsa you should see 220-230 and if you let it sit with the blower under load it goes up to 250-260 on the temp guage.
Albert Lazo said:Wonder when they changed to grey in color?
