Anyone try this sprayer??
steamron
Ron
I saw this sprayer online and thought it was a rather good idea. http://www.green-gorilla.com/commercial.html
I have several pump up sprayers and even used the hydro-force sprayers for years and figured out there is a big saving in prespray when you use a pump sprayer. The sales rep told me that they have sold a few to carpet cleaners, theatthe sprayers battery can last 6 hours spraying and that when you adjust the spray to a stream that it can go up to 20 feet. They also said that it is about 15psi.
Give feed back,
Thanks
Shawn Abbey
Shawn Abbey
I'm not a fan of battery operated sprayers, nor pump sprayers for prespray. The sprayer seems overpriced. I'd recommend a Hydro-Force inline sprayer. Much cheaper and a better delivery system for a prespray.
my $.02
tmdry
Bill Martins
I would never use a pump up sprayer unless I'm putting down anti microbial and or doing a commercial encap job.
Other than that, I have 4-6 different hydroforce jugs, and 2 hydroforce style sprayers no tip, one to use the diff presprays, and one for protector w/ 01 tip.
I seriously hate pump up sprayers.
Only hacks use pump ups.
Use a pump up for encap?
Really?
Really?
Jimmy......maybe you could take your membership here more seriously and come up with some thought provoking discussion that is POSITIVE and maybe even useful.:icon_twisted:
Well how about using a back pack sprayer where you pump a lever on the side?
Probably much better output than a regular pump up .
How is that Fred?
What is this world coming to?
Thats great Jimmy.....
but I thought you would recognize the Foster quote........... :(
tmdry
Bill Martins
Really?
Yes, really
I don't use backpack sprayers, I rather use a 3m sprayer, which I had several of them but the pumps all die eventually. If I'm going to use that much encap prespray I'd rather use my Cimex tank. I hardly ever encap these days, it's all hydroforce sprayer w/ the tm.
Andy McFadden
To the thread starter,
I would recomend looking into making a pepsi keg sprayer, it will cost less and be indestructable, plus you can spray at 80 psi , much faster than that pump up junk. Another good option is the hudson never pump battery sprayer. Just google it , you can find them on sale for $79 at times. It can almost cover a carpet as fast as a hydro force , the down side is you got to carry the heavy thing around.
alazo1
Albert Lazo
For you hydroforce folks...how do you maintain them. Do you just buy a new one every so often?.
Pump ups are a time waster.
Inconsistant spray and area coverage.
Make your time on a job efficent because time is money.
I use a battery sprayer , hydroforce and an electric sprayer which ever will get me done faster according to the job.
The pepsi sprayer is good but who wants to lug that thing around.
And I just can't agree on using a shampoo tank on a cimex.
Flood and scrub and to me it wastes too much product especially when your using expensive $40 a gallon "miracle" internet snake oil salesmen's scampoos.
Yes every couple of years they ugly out. You can replace part by part but when you start messing with a new water jet in the dema and the gun and lance don't look that get we just get new one's. Just replaced one on a truck yesterday and will give the old one to the rug department.
Flood and scrub?
Have you ever cleaned with a Cimex Jimmy?
Five gallons goes a looong way.
clean image
Carl Maddock
What's interestine about OP sprayer is 1air pump not solution pump and lithium is plus
We use Hudson 3 gal bat sprayers work great Cept hose weak
If I understand the pump powerpack correctly, it is a pressure pump, ie it pressurizes the container. If it can't do 40psi it's not worth a dime, You need about 40psi to lay down a decent spray.
I've converted my Omni to a compressor sprayer rather than a pump sprayer. Got tired of the pumps leaking and never working consistently and burning out, at $150/pump, not a cheap fix.
Shawn Abbey
Shawn Abbey
You rebuild the check valve usually once a year or so. Usually after about 3-5 years we replace the DEMA valve. Real cheap and easy.
