these before............are the reliable......???
its a in line thermostat housing..........
As far inline thermo, only concern, farther you got away from engine, with only a pinhole I believe in the thermo, there would be a delay before opening.
Jim, I had to replace my water pump because it was leaking. A couple of months after that my electric fan went out and did a replacement like you did. I got my water pump from PSI engines. They were over $100 cheaper than where I purchased the tm from. Psi engines 1-800-551-2938. I think they are in Illinois? Hope this helpsThe machine would get to hot and shut itself down....I pulled the radiator cap and there was no circulation......
Right now it only seems to be the stat.....I got it out and it had printed on it that it was a 92/107 degree......I thought it was supposed to be a 180/182..... I stuck it in a pan of boiling water with a thermometer in it and got the water temp over 200 degrees and it hardly opened.....
I won't know if it is the pump until I get the new stat and put it all back together.....
i marked the gears....the belt...and the sprockets....pretty sure I can get it back together ok....Sapphire is sending me out the whole assembly tomorrow.....and I am hoping to get it back on the road by the end of the week....
the machine has just over 2000 hours on it....one would of thought a stat should of held up longer then that....
where did you get your parts.....???
