The machine would get to hot and shut itself down....I pulled the radiator cap and there was no circulation......
Right now it only seems to be the stat.....I got it out and it had printed on it that it was a 92/107 degree......I thought it was supposed to be a 180/182..... I stuck it in a pan of boiling water with a thermometer in it and got the water temp over 200 degrees and it hardly opened.....
I won't know if it is the pump until I get the new stat and put it all back together.....
i marked the gears....the belt...and the sprockets....pretty sure I can get it back together ok....
Sapphire is sending me out the whole assembly tomorrow.....and I am hoping to get it back on the road by the end of the week....
the machine has just over 2000 hours on it....one would of thought a stat should of held up longer then that....
where did you get your parts.....???
