Re: Anyone using Mytee's Lint Hog in line vacuum debri filte
The new Mytee filter is stouter and fatter than the old one, and comes in either 2" or 2.5". The only problem with it is the Mytee uses Mytee Cuff Lynx at either end. If you use any other type of cuffs, you'll have to switch to Mytee.
The Devastator is much larger with way more filter capacity, and comes in a variety of configurations. The Dev can have 2 -2" inlets (your choice of inlet connectors), and one out put. For instance, you can run 2 -2" vac hoses to the Dev and come out the other end with a 2.5", or a 2" connector.
The dev has a liner filter inside the SS basket, instead of knee-high. The Dev will also serve as the Y when running 4 to the door, thus eliminating purchasing a Y.
You can clean all day with the Dev, maintain full vacuum, and not have to dump it.
