Ray git em both, That letric reel shore is knice,
Mine is a one of a kind modeled after what Bane sells in there rigs.
Holds 200 ft of 2 inch, has an air pressure foot switch, was used less than 3 months when I got it. (Stole it I did) bought shaft drive machine reels and all in pieces. It also had an APO in the waste tank, a 110 volt version.
We use the letric reel on every job, shore beets winding the reel by hand or trying to coil and hang hoses separately, Easy to keep hose clean and wipe down while reeling in.
Haven't had to use the pump out in couple of years. went to check it out the other day and couldn't get it to prime. Guess I better fix it now that we are using more flow in our cleaning process. Might need it a might bit more.
