are you replacing your hose every six months?
According to this article in the new cleanfax, you'd be an idiot not to..
Has any one ever had Parflex blow catastrophicly?
dgardner
Dan Gardner
High-heat folks need to be especially careful due to the high stress on their hoses IMO.
jmo
Jeremy
Our hoses are over a year old, time to replace I guess.
Charlie Lyman
Charlie Lyman
I replace the lead hose annually. Havent had a blow out since I started doing this. 6 months seems excessive for me. Maybe if I was busier.
Seems like @GeneMiller clear 5' sleeve over your lead hose is the perfect protection in home... I want to know where his hose broke?!? Cutting 6" to a foot on each end should be sufficient every 6 months... I did have a para-flex hose kink in the middle and bubble...
I just started using high heat and this is a good reminder to check hoses periodically, in-home and outside....
Steve Lawrence
Never a blowout with the Parflex going on about 5 years now. Failures were limited to a warning bubble which got our attention so we could repair.
Several blowouts with the old wire braid Goodyear Neptune.
Reactions: Dolly Llama
mirf
David Mirfin
Once A year on the 1st one hundred feet.
same as Steve
Had more instant blowout failures in the year and a half I used Ineptune than in 23 years of using Parker Parflex.
been pretty vocal over the years about my extreme dislike of steel braid Ineptune .
there's NOTHING good about with the exception of it's flexibility ...other than that, it's all bad points ;
it's extremely hot to touch (will permanently disport olefin/poly carpet if your TM makes hot water )
Doesn't carry as much heat to the wand as Parker
it's heavy
prone to black death
gives no warning when it instantly bursts and squirt black gunk on walls and carpet
(or worse, 200+ degree solution on the operator)
I think it's dangerous and wouldn't hit a dead dog in the azz with the crAp
I didn't read Jeff's article, so maybe he mentioned an industry average of what "6 months" of use is .
If not, it's useless otherwise...as " 6 months" is 200 hours to some and 600 hrs to others
gtech12v
once a year for safety and love the new look of the hoses , can not stand old and dirty hoses
FB7777
Anyone have a link to a parflex distributor?
Time to replace my butler lines and want to try something other than neptune
I was pretty impressed with the nylon braided Neptune hose on the Butler at Santa Cruz MF.... The rating on it was 1500psi at 230° if my memory is correct... I could hold onto the hose even with my soft ass grabbing hands....
Reactions: Mark Saiger
GeneMiller
gene miller
The first year in business my hose popped cleaning marble. To make it worse it broke while I was at the machine. It hit the ceil and a large curtain. It was pretty bad. At that time I had never heard of the problem or knew the connection was a weak link. It wasn't uncommon for me to lay the wand down bending the hose back.
I've seen cars drive over pressure washer lines no problem. I didn't realize these weren't as tough. Since then I had a section of clear 5/8" I.d. as my relief. All that happens when it pops is a dribble out the end. The 5/8" fits snug over the metal fittings so you don't need a hose clamp. It's a pain to install over the end but with a strong string a little lube and two people it's quick. Only once since has the hose broken somewhere other than the connection. Hint , don't let heavy commercial doors slam on the solution line next to the hinge.
Gene
Hate Parflex. In fact, they should not be allowed to use the word flex. It's a coiled up nightmare to use.
I love Goodyear.
Replace it once a year.
realclean
Jesse Lowe
I've been using Parker ParaFlex for over 10 years and have never had a blow out. Like others have said, it will bubble first to let you know its time to repair or replace.
Cobb will make custom sizes.
Wing It
John Wingfield
Goodyear Neptune replaced every year. Before I replaced yearly, it popped a few times but no good stories to tell thankfully.
gtech12v
Vacuum too?
I replace my vacuum lines also only the first 100ft the ones that look old
when I get the new goes to the back and the one with less use goes to the front
a good way to keep things looking nice
steve frasier
steve frasier
I just replaced the 3/8" on the hose reel. It was almost 8 years old. Don't run steel braid in the house. Been 3 years on the current hose paraflex.
Doug Cox
Doug Cox
I've had a crimped fitting come off at the wand once in 30 years (last year). Probably a bad crimp. All failures occur at the machine for me and I replace the hose whenever the failures occur regularly. John Olsen will cut it to whatever length you want. BTW- Does anyone have dye transfer from the hose to carpet at the "Tool End" of the hose? For the last few years I've had the blue dye transfer from the hose to the carpet right at the stair tool (never but on stairs), and it doesn't come out.
Never had that happen. But I buy Baptist Goodyear hose.
That Mormon stuff is finicky.
