- Joined
- Oct 6, 2006
- Messages
- 116,964
Up for auction:
1 Rotovac 360XL with choice of head.
1 Sheardry upholstery tool
Free Shipping to lower 48.
3200+ Retail Value
Bidding starts at $1800
$20 Minimum bid increments.
Auction ends 5/1/18 at 6PM PST
About the 360XL:
High Performance Carpet Cleaning Machine
Engineered by Cliff Monson, the inventor of Rotary Jet Extraction, the 360XL is designed for high performance carpet cleaning. The 360XL has multiple cleaning head options, a telescoping handle and weighs 68lbs. The Swoop Glide™ vacuum shoes eliminate over-spray while deep cleaning the carpet with unparalleled results.
Rotovac 360XL Product Details
The Rotovac 360XL is a Patented Rotary Extraction Power Head that utilizes rotary vacuum heads to thoroughly deep clean carpet with hundreds of multi-directional cleaning passes. The 360XL weighs only 68 lbs and is extremely easy to use as it operates in a self propelled side to side motion. Simply stated, “The 360XL cleans better with less effort."
Works with most Portable Extractors or Truck Mounts
The Rotovac 360XL is air flow calibrated to work with most portable extractors or any truck mount extractor. Give your business a boost and your back a break by hooking up the 360XL to your existing portable or truck mount.
About the Sheardry upholstery tool:
Rotovac ShearDry Video Demo
The Rotovac ShearDry Upholstery Tool cleans in both directions with no overspray or dripping. Constructed of light weight super strong fiberglass reinforced composite, the ShearDry is the most comfortable and effective upholstery tool on the market today.
(Back to top)
Up for auction:
1 Sheardry upholtery tool
3200+ Retail Value
3200+ Retail Value
About the 360XL:
- Features:
- Cleans better with less effort and leaves carpet drier than a wand
- Large 15" wide cleaning head
- High torque motor with tough helical reduction gearing
- Patented Swoop Glide™ vacuum ports
- Telescoping handle for compact storage
- 144 RPM
- 55 lbs (without cleaning head) 68 with head
- Rugged cast aluminum frame
- 2" clear view tube
- Unique marketing tool, land new accounts and generate referral business
(Back to top)
- Dual Direction Spray Bar Centered Between Two Vacuum Slots
- Fiberglass Reinforced Composite Body - Strong & Lightweight
- Vac Slots Close to the Front & Side for Better Edge & Corner Cleaning
- Solution Holes Are Only 1/16" Apart for Streak Free Cleaning
- Thin Side Profile for Better Reach
- 10' Hide-a-Hose With In-Line Filter
- Super Comfortable Design for Less Hand Fatigue
- Easily Replaceable Cleaning Head - Only $19.95
Up for auction:
3200+ Retail Value
