Baby Oil?
Bucey
Whoville
FFA?
any one ever had to get baby oil out of carpet? alot of oil like in a vase! its down in the padding, about a 3' x 3' area. regular cut pile w/w. I have not seen it yet.
Arizona
spot claw/water claw and start flushing it with the hottest water you can get your equipment to give you..........
John Olson
Orem UT
John Olson
If you can, cut the pad out do that then lay plastic down before using the claw. Easier to remove the pad with the Baby oil then to try and suck it back up and through. I would mix up some extreme clean, powerstrike,powermaxx etc (somethign designed to eat oil) and satuarate the area then water calw it while using your solution line to flush the carpet while using the claw. After your done extracting you should put down some Stain Blotter, Diatomaceous earth which will help pull any oil that was left behind.
Good luck and be sure and take pictures and post them :)
harryhides
Canada
Tony
I'd agree with John, have done a couple of these.
Last step you can also use Capture Powder to absorb the last traces of oil and vacuum out a day later.
