Duane Oxley
Moon Unit
I thought I'd post a, "baby picture", of the revised Predator design. Over the last few months, in addition to designing the heat exchange system I've mentioned here, I've also improved the frame design of the Predator systems.
The new design is open, which allows much easier access to the pump out pump in the event that the impeller requires cleaning.
It also features a motor plate that slides forward (with the motor in place), to allow easy de-coupling / re-coupling of the motor and blower. This allows quick coupling insert change, belt change, and, at the same time, does not affect the motor alignment during the process.
The one shown below is of one that was in the process of being assembled.
The HX system (I've all but decided on the name, "Prometheus", for it), is being built on a frame that's very similar to this as well...
More later...
More later...
