Bane-clene
White Collar
Bentonville, Arkansas
Nick Petersen
Anyone use their detergent? I mostly use bridgepoint poducts, I like Endzone but didn't like point blue, so I was looking for something stronger to replace point blue.
Never used any Bane-Clene but have heard about it and it sounds good.
I tried some MANY years ago.
PCA(?) or something like that??
if i recall right, it was good stuff
Is Point Blue an emulsifier you run thru the TM?
if so, try some Genicare Clean-it.
I bet you'll like it.
It's not the easiest powder to mix and is a tad bit foamy for my tastes,
but the fragrance is GREAT and it cleans pretty darn well
steve r
pca 5 will destroy aluminum pumps so keep that in mind.its what i use daily. dries clean very little to no residue.cleans like the dickens even with cold water.i wouldnt know how well it works with high heat but ...
and its very affordable to use.
White Collar
Nick Petersen
Meat, Yeah its an emulsifier that I run through.
I'm going to google that genicare and take a look at it.
Is that what you use on a daily basis?
Thanks
bob vawter
Grassy Knoller
La La Land
bob vawter
NAWWWWW..don listen to The MeathED on the Clean-It....Genie Care makes SuperClean THE emulsifier to run through the machine...no foam!
Oh yea...don furget the THREE GULPS of Genie Care 1300/5 gal..........
Thanks
Nah, i bought 50 pounds of it to try.
It's good stuff, but because of the issues I mentioned, I went back to prochem Heat wave.
I really only run emulsifier to add fragrance, and water conditioners.
If I cleaned like some outfits do that don't pre-spray and only run cleaner thru the TM, I'd probably use it all-de-time
BTW, the stuff Bob mentioned is NOT approved for stain resist carpets.
The PH is too high.
That's why I've never tried it.
That may or not matter to others though
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
If you want an emulsifier that is stronger than Point Blue, try White Lightning. A great cleaner but the pH is high for stain resist carpet.
White Lightning has a high cloud point that makes it work great with high heat truck mounts.
Scott Warrington
vincent
O'Fallon, MO
Vincent Sapp
Bane's PCA 5 is very good, but has gotten pricey the last few years and if you don't use their (red) booster (more costs) it doesn't work as well.
I left the PCA 5 to try magic potion. Works well as a rinse, but too expensive just as their "green labeled trashed".
Then went to Geni-Care Deluxe Super Clean. Does a very good job, but didn't really care for the smell.
The best one to use IMO is the Judson 02 system. Get the hot sauce modifier to enhance the prespray when needed on the nasties.
I love the Clean-it (foam and all), but I couldn't get Bawb's Delux to work all around, and frankly I'm a little shy to be running high pH degreaser through the machine, Delux is already high, the 1300 is nutz. Clean-it does have one of the best scents ever created.
Ain't too many Geni-Care dealers on the planet, hopefully you have one close.
DBOSS
Baneclene
Yes I've used most of Bane's detergents for 10 yrs. pretty good stuff, but having a lil better results with Chemspec in last year.Still running a Baneclene 1996 truck mount but getting ready to give up the ghost and purchase a real machine. LOL
Kevin
PCA 5 is best on market
Clean-It is good too.
RAGE is a decent product.
Judson didn't get the results the customers in my market demand.
I agree we used it many many years ago, cleaned well smelled great. Not sure it's designed for high heat, I'd be concerned with it falling out of solution. Probably better products out there if you are running a TM.
