Bar Soap bliss
boazcan
Tampa Bay/Central Florida
Bryan C
awesome. what did you rinse it with?
Is that shower older than you?
I had a shower like that once that I stuck a mini turbo on, and it sucked a tile off the wall. Try matching that tile.....
after scrubbing the soap off, I washed it down with Cobb's Acid and a tan pad and used the shower head to rinse it all down the drain.
Royal Man
Lincoln NE
Dave Yoakum
Dry wall sanding screen(with a soap scum remover) is an easy way to remove soap scum from ceramic tile. Give it a try.
Louis
Modesto, CA
Louis
What do you get for a shower around there? If try to get more than $200 around here they think you are ripping them off. I stopped doing them.
