Jeff Brown
Anyone using the Bently wand?
How do you like it?
Pro's and Con's ?
Thanks
How do you like it?
Pro's and Con's ?
Thanks
PCCN said:Bought one when they came out a few years back to get under restaurant tables. Was good initially but after a couple months use, the grip on the handle gets loose and the company SWEARS all you have to do is tighten it up. If ours was any tighter it would break the bolts! Also, was told we could use it without the glides. NOT POSSIBLE! (The head where the glide slides on is not machine smoothed and won't slide across any carpets-period.) Glide does wear out very quickly. Suction is pretty good on short comerical grade carpeting, but NOT on residential. Absolutely doesn't pickup the water nearly as well as our plain PMF or Pro-Chem wands. Plus, the price is rediculous for what you get. We have seen they stopped their huge advertising campaign and changed the design a couple of times since we bought, so this lets you know its NOT a big hit with cleaners.
