joeynbgky
Does anyone have problems with berber streaking? My technician is asking me. He says sometimes there are lines in the carpet. Any have any suggestions how to fix this?
joeynbgky said:not heavily soiled, jus normal
Not at the edges of wand just at the top and bottom stroke
not sure if it was olefin berber
Doug Cox said:You have to let off the wand trigger before you hit the end of your stroke.
gregcole said:Finally- this is precisely why our guys only dry-clean berber.
Spurling said:maybe the wand lips are getting pinched in the center due to high suction and flat carpet or maybe lint clogged
gregcole said:Larry - 98% of all problems cleaning carpet are operator error! If you eliminate the possibility for error - there is none...
joeynbgky said:Could the previous "dry cleaing methods" be causing some of this?
meAt said:gregcole said:Finally- this is precisely why our guys only dry-clean berber.
because their too inept to learn proper wand technique? :roll:
98% of the probs cleaners have with berber are operator error
What you have is zebra striping. You need to listen to these guys, they know what they're talking about. It's all in the stroke. Your tech will need to learn before your granny can learn. (glide or no glide). Also very common with cgd olefin,or padded.(the cheap SHIT). Releasing the spray before and the end of your stroke will help you huge.joeynbgky said:I probably need a new wand anyways. its nto old its just the standard. One they gave me with my truckmount. je-jet crap. any suggestions on a new wand? I dont want to spend $800 bucks on one.Maybe one with a glide, so my grandma can clean carpet too. LOL
