lust1kiddo said:
Every time I clean Berber it comes out like shit..and when its white, it looks still dirty when its drying. I have a 100 psi porty and my powdered 90..and it frustrated me to the point where I actually tried to do one room with the hand wand to get it clean..I need help.
Thanks,
Jarred
Iseeru
is powdered 90 an emulsifier you run the machine?
try a strong butyl laced pre-spray
add agitation.
mechanical is best, but grandi brush (not the rake) will help too
even stiff bristled push broom will work great..(probably better than a Grandi brush)
Don't add a bunch of soap in the porty rinse.
1/3 or less of what's recommended for porty use is fine.
all you're doing is conditioning the rinse water...the pre-spray does the heavy lifting
there's no reason you can't get an olie berber clean with a 100 psi porty.
you need good chems, agitation and a good rinse/extract
and don't forget to vacuum first...it DOES help in many situations..especially with a porty
whether you need to "Ron Wernerize" it depends on the dry soil load
