Best product or method for removing black shoes marks off heavily waxed gym floor
I did most of the grocery stores and a few department stores in the area when I was younger..much younger.
By the time I turned 30 figured out I liked carpet better.
Just a light coat around the edges. And for good measure put more coats in the middle of the floor where it gets more abuse. : )
Bruce
Jimmy I would think that would be unnecessary for a gym floor if that's all it's getting used for. I have a gym floor I do strip and wax once a year , if they are only using tennis shoes you won't see much wear.
This floor doubles as a community center event room, roller rink, volley ball court and more
Andy
Doesn't Matter
Plan on two coats. do the math for lowest amount of coverage / gallon plan on buying that. The first coat will use more than the second coat. Call your chiropractor and tell him you need an appointment for the day after. If you have someone to help you, have them pour the finish on the floor in about a two inch wide line. Then come behind them spreading it out.
Reactions: Josh and Mikey P
Josh
Josh
Perfect.
You may put a 3rd coat if that's the case.
Did you get buffable wax?
I have a 20" buffer I'll sell you cheap.
