Best VCT Mop
Shane Deubell
yes the rubbermaid flatmop system works good for larger areas but for detail the microfiber flat mop is way better. Easy to clean also
Utah
rubbermaid system....
ifn you dont have big areas to do per dip.....just pour....like Dr exam rooms....
MicahR
Billings, MT
Micah Richardson
Google KaiVac Finishing Pad.
Forget using a Kentucky style mop to apply finish. Dinosaur technology.
A flat microfiber flat mop is a great way to go.
Benton KY USA
"Kentucky style"....lol
I don't use mop buckets or string mop heads at all.
For applying finish to large areas I use a modified 18" dust mop head. On smaller areas I use a white towel folded as a mop head. And on the smallest areas with detailing I use a 3M Doodlebug with a white cotton sock pulled over.
aurther11
I can't give you the best since i've only used one, but i've used Armstrong Excelon. It is available at Lowes and Home Depot for about $20 gallon, which i've gotten about 1500 - 2000 sq out of a gallon. It gives a reasonable shine when applied with a mop, though not a mirror finish. As far as lasting, it looks like i'm getting around 3 months between adding a couple of coats.
