Best way to clean over 1000 cgd steps
davegillfishing
dave gill
We did 100 of them with a makita grinder and a cimex pad with releasit..that wasn't too bad but is there a better way?
HWE with a stair tool is faster than anything discussed thus far.
Is your real problem that you don't own a TM?
Reactions: steve_64
We would Most likely also HWE, but depending on hose run limitations not sure what my other attack plan would be. The little Pullman Holt unit did look cool when I saw it at connections.
M
Mardie
I tried the drills with cotton pads and cimex fiber pads and could not believe people were actually doing this . The drill threw the crap and moisture all over the place, makes a real mess. OP would be a much a better choice if this is the direction you are taking.
Reactions: hogjowl
davegillfishing
dave gill
no option to hwe with the trucks..i dont have a porti and would rather not use one..
the angle grinder with the pad driver and a fiber bright pad worked great just gunna be hard on the quads
for the guys
ok its looking like theres no real great way to do them other than what i have already done..
i could hwe 1/2 of them but am not a fan of mixing methods..
thanks
The cimex pad does a great job of breaking it up but a combo pad or microfiber will do better at picking it up. We use a Cyclo car buffer and it does a great job on the bull nose but is a bit of work if you have that many steps. The torque will wear you out worse that if would have just steamed them.
Maybe a padson or something similar.
Royal Man
I clean steps all the time with a 12" oreck encap juice and a microfiber pad. Beats the hell out of using a drill ot angle grinder. The head pivets to get the fronts and sides. And you can do it whle standing up. Start on top and work down. East peasy. And great results
Jeremy
Jeremy
Get a few orbital car polishers & some velcro. Glue the velcro to the car polishers and you have a mini op machine/knock off Stepson. Or you can subcontract it out...
Jeremy
Jeremy
Yeah, Tuways and fiber pads... Something else that worked well for me was microfiber towels (found next to the polisher at Walmart).
davegillfishing
dave gill
Got a stepson. Doesn't seem like it will work as good as the angle grinder though..maybe I'm wrong but I just feel like the results would be as good..I will try a few 1/2 and 1/2 to see..
I will look into a few other suggested options too
Thanks
I'd say it depends on soil load. The heavier the soil load he more I'd want to pick it up with pads. At least the tread and bullnose, the risers are never very dirty so it wouldn't matter which system you used on them.
Royal Man
Thanks
Just get an Oreck a few pads and a driver and you won't have to play games with angle grinders
davegillfishing
dave gill
I left out that there is no bull nose or risers just the top of step. They have a plastic strip on the edge
I'd think if you sprayed them heavy with your Releasit, you should be able to do a great job with the Padson. We use Vacaway's Encap green and they come out great.
Cleans fast, looks great and dries fast.
Reactions: hogjowl
