Birth of a Waste Tank.
Cylindrical are ideal, with dome or conical ends.
Still need baffling for slosh, airflow, and damage control.
Look at a 55 gallon drum, specifically the ribs rolled around the circumference.
That helps resist damage from side impacts.
To minimize sloshing a perforated panel can be included.
Deflection panels at the top guide incoming water downward away from the vacuum source, minimizing turbulence.
bob vawter
Grassy Knoller
bob vawter
hey Lee.......that ridge around the drum....would you say it a "broke or a break"...>?
bob vawter
Grassy Knoller
bob vawter
You're that guy on Pawn Stars wit the beard and funny hat.....
bob vawter
Grassy Knoller
bob vawter
Whadya think.....do they make the roll on the flat stock.....or after they they form the cylinder. ...?????
rick imby
Rick
Wow , I would have guessed on the Flat stock. I've seen them make Aluminum bicycle rims---like they were a curly fry. They feed the extrusion through the rollers and about 6 rims come out of one straight piece.
bob vawter
Grassy Knoller
bob vawter
Ahh HA....that was a test question. ....you can not roll a cylinder shape between two rollers with a bead bend already in it.....Lee is one sharp cookie.....
