Grant D
I've been using this new model for about a month. Though it's pick up ability is good I'm not terribly impressed with it.
My issues:
1. Have already replaced the belt twice. They're cheap so no biggie. Can tell when the brush isn't spinning optimally by the sound.
2. In mine the sponge filter is very dirty after even one job. All find dust but seems like more should be staying in the dirt cup? Again not a biggie, can just stock several sponges and swap out after every job or two.
3. Hepa filter is already black after a month. Yesterday vac wasn't behaving right, the hepa filter was basically clogged. Got a big face full of dust when I checked it out. Probably b/c the job I did yesterday had a lot of fine white powder in it that got through the sponge filter. But seems like 1 month out of the hepa filter sucks, and I've had a headache since yesterday when I got the face full of dust, not fun either. Can these be washed and re-used or have to swap?
4. Seems like dirt leaks a bit out of the cup, the vac on the sides near the top of the dirt cup will have some fine dust after each job that has to be wiped off.
I like seeing what I'm picking up as it helps tell me what speed to vac at, but maintaining this thing is a PITA compared to my other vacs (lindhaus and royal). Do you bissell lovers have these issues? Maybe I need the Healthy Home model instead?
My issues:
