Blocks and Tabs
We had inconsistent results with sticky tabs.
Its been awhile since I had any more problems....but for awhile there..I was getting rolls that about half way thru were not perforated and I had to cut the squares.....I little more stickem on it and I could of used it for box tape instead of tabs.....................
We get a Yellow Foam Block from our local (well 3.5 hours away) vendor in Minneapolis, MN (Barker-Hammer). Not sure where they are made, but they are a more durable and dense block....
Better than the Blue Blocks and the white blocks that have been offered around here.
And both sizes of Sticky tabs are our main tab.
We have some 4 x 4 Teflon tabs too....but I usually give those away to some over eager client who moved everything out, then last minute decides they want to set things back their way... :cool:
I know all of yall are waiting to see what I use.
I'm not telling unless yall don't bid on the Magic Wand Grease Eater raffle.
Luis Gomez
Luis Gomez
Blues blocks and Joe's glossy 4x4 tabs are the best, the roll of sticky tabs hardly get used.
