finally found time to work on this thing and get it to stop leaking.....
pulled the rear cover...
wire tied it back up out of the way as far as I could to the therm oil hoses...
cleaned both surfaces and applied some High Temp RTV silicone gasket material..( Nickey would of been proud of me ).....and put it all back together.....
total time 2 hours.....
1 hour to repair..and 1 hour to set and cure before I put in fresh oil..started it up and tested it.....
problem solved......
sorry Mike but smearing JB weld on the bottom of it just did not set good with me.......?
