I have a slide-in with a Honda 24 HP engine, and a Roots #4 blower.
The Honda has an 8" pulley, and the Roots has a 7" pulley. I am "over-driving" the Roots for more CFM (dual wand truckmount), and the larger sheaves will give you more belt surface contact. I run a single "B" belt, MI belt tensioner, and usually get 1500+ hours easily out of one belt.
I have a tach/hour meter, so as I REV up the Honda, I can stop at whatever RPM I want the engine to turn. I assume your Kohler also has a hand operated throttle that can stop anywhere along the way.
If so, you already have control over operating RPM, so concentrate on whether you want the blower spinning faster than the engine RPM, or slower.
I usually run at 3000 Rpm's, and do NOT hear any bog when the machine is under load, using either single or dual wands.
