I'm having issues with my machine, a Blueline Bluewave, suddenly dropping to idle while I'm in the middle of the job. This has been an ongoing issue for quite some time; however, the problem has become much worse this week. This machine has been well maintained, and works great except for this frustrating issue. I have the manual and have gone through the troubleshooting.
I have done many things to try and resolve the problem, including: changing the battery multiple times, upgraded to a larger battery, fixed/tightened ground cables, changed power cables all together, tested alternator (it tests fine; though I have a spare), changed the radiator, gone through most of the electrical, fixing/tightening connections, etc...
The best part is, the mechanics cannot find the problem (it never does this for them). They are unable to test for the problem unless it actually exhibits said problem.
Anytime I replace parts or tighten connections, it seems operate great for 1-day, then it goes back to the idle issue the following day. I suspect there are probably multiple things happening. I know that it is either an electrical or heat issue. I suspect heat, because I seem to have less trouble the lower I turn the heat, or on a nice, cool, windy day.
Currently, I suspect the Rostra-Vernatherm bypass valve under the waterbox... And also the possibility that the vacuum heater-core may be gummed up. But I also wonder about the engine's thermostat (which I have, but haven't changed) and temp sensor on the Kubota. I also wonder if it's the computer, or the electronic throttle control wigging out.
Does anyone have knowledge or experience with this problem on Bluewaves?
