steve g
on a tip from this board, I bought a bosch laser measurer, I had been using the fat max laser for some years, IMO this bosch unit is much better, it does an audible click once its measured the distance, so no wondering if it captured the distance, also with the fat max I would get some crazy readings from time to time, with this unit, I get very accurate consistent measurements, the fat max almost needed to be completely stationary in order to get an accurate readings, this unit works just fine with the lazer dot moving all over the place I am very happy with it, the laser dot also seems to be brighter and easier to pick up. at this point its a better unit in every way if you had been using the fat max. if you didn't get one you missed out!!!!
