Meter Maid
The Undetective
- Joined
- Nov 29, 2017
- Messages
- 3,867
- Name
- Chris
See if Michael’s finally wrong.
You’re still here.Be gentle with the pigtail
Obviously, which is why you’re all old and unattractive.Long before you
Yeah no thanks, two top heavy and fighting that swivel. It gets old for the slight benefit of getting in the areas that don't even need vacuuming to begin withShark
I can wrap a bonnet around my cowboy boot with the best of them, we don't cut corners, we clean them!Well, you’re a padder now.
So you can’t clean those places either.
I can clean residential much faster with HWE.Well, you’re a padder now.
220, 221, whatever it takes.pre-COVID you could get the commercial 40 ft model for 120 bucks now. I think they're 220
AKA: making customers happy long term?I’m just obsessed with doing thorough work.
Marty is obsessed with cornrows
Great goalI’m just obsessed with doing thorough work.
That's why we have a truck mount and a open vac hose for edges.If you're first complaint is that it doesn't edge well, take more meds.
I also carry a Kirby just in case I run into one of those ultra stiff polys or an ultra thick shag rug.
And if the carpet needs edging, either use my truck mount or the little Hoover porta power..
But running a orcs XL commercial is as easy as can be. The bag will hold pounds and pounds of crap. They're super cheap to work on and/or replace, fantastic for stairs as they're just the right size and easy to manipulate and groom and fluff the pile like no other vacuum I've ever used and I pretty much use them all.
But where ear plugs or crank your tunes as they're pretty effing loud
