carpetcleaner
- Joined
- Mar 5, 2010
- Messages
- 520
- Name
- Rob Litwin
My 421 just started to have problems with the high temp bypass/dump valve (dumps water into waste tank to keep from over heating). The water bypass valve started dumping all the time.
I usually bring my TM to my distributor to have repairs done. They can see me Monday, but I'm working this weekend.
What I checked:
I unplugged the wire (power for the valve) for the bypass valve on the temp control unit and the bypass valve closes.
The potentiometer doesn't seem to do anything. When normal, you can here a click when it switches between heat and bypass mode. There are 3 wires; red, blue, black. Ohm meter on red & blue the resistance changes as I turn the knob. I do get a few open areas as turning so I need a new pot, but it isn't causing dumping all the time. The black wire is open to red or blue, and ground.
The solution temp sensor is showing open when checking with an ohm meter. I think that the sensor is bad. It could also be the temp control unit. Not sure how to check it. Will jumping the pins at the control unit cause the bypass valve to close? Unplugging it doesn't.
What I checked:
