Boxxer 421 Tune Up
Blue Monarch
Dirk Wingrove
Took the 421 in yesterday for a tune up. On a recommendation, I took it to a local small engine guy. Here's what he did...
1. Change Oil & Filter
2. Adjust Valves
3. Inspect plugs and wires (I had just changed plugs)
4. Removed and cleaned carb
$85 out the door.
I thought it was a bargain. I've never had the valves adjusted before, but man, did it make a difference. Thing runs so much better than before.
I've read threads before about having your valves adjusted, but never really gave much thought to it. Live and learn.
Man I gotta quit going to JonDon for service! I can't get out of there for less than $250 in B.S service and labor charges. I should work on finding a local small engine guy in Seattle!
The Magician
Good deal. Check your owners manual adjust around 500-1000 hrs. It was a yearly winter slow down maintenace thing along with chaning belts.
BillC
Now you need to give Greenie a call and he will tell you how to make your 421 a little beast. If you havn't already!!
