MB Auctions
- Joined
- Sep 15, 2014
- Messages
- 92
Brand new Turbo Hybrid TIle Spinner
The Turbo Hybrid is the ULTIMATE hard surface floor cleaning tool! The Turbo Hybrid blasts soil and dirt from tile, grout, and smooth or rough hard surfaces. Cleans 500-1,000 sq ft per hour. The rotary arm spins to create amazing soil blasting power working from 500 to 2,500 psi while the vacuum ports pick up all the waste. The Hybrid is ready to work with truckmount carpet machines, pressure washers and vacuum systems, or high pressure portable extractors.
- Works on uneven stone, tile surfaces, or smooth concrete
- Light-weight
- Low profile; gets under counters
- Non-Fatiguing: glides easily over the floor
- Extra long life hard boot ring and nylon brush ring are standard equipment
- Easy access inline filter
- Unique airflow system allows use on portables or truckmounts - both with excellent solution recovery
