Built a dual blower setup - few questions
AshleyMckendree
Versailles ky
Ashley Mckendree
Ive built yet another dual blower setup for my Direct drive Ambulance, I think this is the third dual blower setup my father and I have setup over the years.
Its a roots 45 and a roots 36, I thought about using a sutorbilt #4 in place of the 36 but its mounting feet are cast and I wanted both to be horizontal.
The main reason for doing this is so we can run the machine at slower speeds and still maintain a decent CFM,
The problem im running in to is at lower speeds (Van @ 900rpm, blowers are spinning at 1800rpm),
It 'sounds' like plenty of cfm at the wand, more so than just one blower at 90/100% blower rpm, but not very much lift.
At what rpm do I need to run these blowers to achieve there full lift capability?
And if I water inject the blowers will they reach higher HG lift across all rpm ranges?
P.S. This thing makes my glided GreenHorn SCREAM when I set the RPM at 90%, at the end of 200ft of hose, so loud it freaks out my customers... im afraid to even try 100% rpm!!
How do you Vortex guys deal with a loud wand??? I imagen I still don't have the CFM of a V!
Johnny
La-Z-Boy
Johnny
Interesting.
What's the advantage of two blowers vs one bigger blower? Can you disengage one blower?
AshleyMckendree
Versailles ky
Ashley Mckendree
Advantage 1 is I HAD 2 blowers laying around,
Advantage 2, if one fails I can take it's belt off and continue with one blower.
Currently the only way to disengage a blower is to remove it's belt.
Dallas, Texas USA
Ashley;
The #45 blower is capable of much higher lift than the #36.
The blower with the most lobe wear is probably limiting your lift @ 1800 RPM.
I would try each blower inlet separately to check the lift developed @ 1800 RPM.
Doug Cox
Delavan, WI
Doug Cox
And what is the liklihood of a blower failing? Not much in my world.
Sent from my Desire HD using Tapatalk
