Butler High Heat and Zipper wand at 12 flow and 240 plus heat.
Was at a crematorium today....
Hot as all blazes in there but was still making steam at the Zipper....
So shot a quick video....
Reactions: Bruce Humphrey
Just checked the settings and set to public....should show up....
Unless I am missing the joke :)
Steve Smith
I like how you cap off your vacuum the whole time ... LOL.
Please someone send Mr Sager a lie detector he can use at the end of the hose run... Would like to see what the temperature is at the tool, at the truck means little ...
P.S. Did you find out how fast your blower spins on the highest setting?
Is it over 3,000 rpm?
Know it is 1750 RPM, the hose capped off to keep RPM in check and also to emulate the zipper on the floor....listen to the air still escaping.....
It won't be 240 plus at the Wand as we all know, but it makes heat....
Will have to research what it is the Butler does spinning their blowers again as I asked and posted one other time here.
I would guess 210 at the wand or close....but that is based off a friends lie detector test with a 10 flow and in 30 degree temps....so it could be higher in this instance today at the wand, but I am running 12 flow and he was 10 flow in that cold
generally my guess would be 240 atm transaltes to 190-195 atw with a high flow wand.
I do have a lie detector. Both my 405 could do that on a really hot day.
My SS 570 will hold 200 to 210 atw I'll shoot a video for you.
Thats hot Mark plenty of heat
Reactions: Mark Saiger
Mike Draper
on a really hot day in the summer with my high heat butler it would be around 190 at the wand and 240 ATM.. I have a temp gauge on my high flow TI wand. Running the rotovac it was around 200 as there was more lift in the blower and more heat. In the winter, forget about it.
hooraybeer
Dave
190 atw is about right for a high heat Butler. Doesn't matter if the temp at the machine is 220-240 atw stays pretty consistent. I made a $20 upgrade and get a steady 200 atw with high flow @ 600 psi.
Rode with him in Scottsdale out to the desert and back. He was in one of the Jeeps that kept track of me. :biggrin:
TM build?
Was Draper the red headed guy I met in Fla. last summer? Bought the Tomway wand?
That guy didn’t have enough sense to get out of the rain!
:headscratch:
JS41035
I though h was the guy with the tnt units that built his own stainless steampunk looking machine.
DAT
Bill Cheryl
Did you kmow that the crematorium offers discounted price for the 3rd degree burnt victims?
icleancarpetz
Rafael Samson
did The enviro-mental police fine you for polluting the sidewalk with all them soap fillers??
