R
richd8980
How can you tell when your blower is going out? Does the blower get clogged up and can it be cleaned?
rctpks said:When we've lost them it was obvious they we going out.
You could hear a clicking as you shut down, metal hitting metal that was not and should not be there.
rctpks said:The lobes were hitting from the timing being off.
How did you fix it Bob?
I think we've lost half a dozen in 42-years. A few of those were costly, both in price and it lost income.
Had one on a Butler that was sold and we had flooding so we decided to use the truck before they picked it up. Blower blew up, probably better it happened to us than to them just after we sold it.
Had another that went out during peak flooding and couldn't get a new one until after it was over.
Over all for the abuse they take they do really well.
No I don't think you do!I KNOW what it sounds lik ricHard....but in reality what you're hearin' is the buildup of SOAP on the lobes hitting the case!
HARPER said:Richard,
The last 3 Butlers I owned all had over 5000 hrs....
Never lost a BLOWER on any machine :!:
IMHO the Butler doesn't respond well in the RESTO-BIZ......"unless it has an APO"
To many "clutches & belts"....It can't clear the blower FAST enough...When Tank Overflows.
If this occurs...The BOX silencer is so restricted ...to keep it quiet...That won't allow the
HIGH VOLUME of water to clear & recover fast enough!!! "LOT OF BACK-PRESSURE on blower.
PLUS : the Vac. hose MUST BE set-up DIRECT....Their hose reel takes FOREVER to clear
excess water... BACK-PRESSURE is a blower's WORST enemy!!!!!!!!!!
The restriction & excessive heat that occurs....Will over heat bearings & cause blower to
JUMP TIME....or pick-up a peice of TRASH & chip or BREAK a lobe...GAME OVER![]()
HARPER said:I don't clean anymore......I am BaWb's THERAPIST NOW 8) 8)
BawB: Hook the Vac hose DIRECT to waste tank.....NOT use the live hose reel :wink:
HARPER said:I can't imagine how LONG it would it would take read the starting INSTRUCTION'S
on the ShaWn GeNie.....
BTW: My critical PatiEnT....I was talking about removing the VAC HOSE ...
from the LIVE HOSE REEL....And hooking it DIRECT to the waste tank....
Allowing HIgh volumes of water to travel FASTER to the waste tank.....
Thus BY-PASSING the hose reel :roll:
