Out of Character - 0
I want some additional heat. Here's what I'm considering doing, please give me any insights or advise you have:
Adding a heat exchanger under the truck on the exhaust, the current system consisting of a single pipe. I'll ad a y, manual diverter to regulate flow, then the heat exchanger. I'll run coolant from the truck through the exhaust heat exchanger, then the coolant will pass through the machines coolant heat exchangers. Our trucks already have a additional electric fan that runs when the tm is in operation. I would also seek the highest temperature rating for my coolant.
My thought is that the coolant will always be flowing the same volume, by adjusting the amount of exhaust it receives to a safe flow I should be able to have one preset temperature.
