jstucky
- Joined
- Sep 12, 2008
- Messages
- 451
- Name
- Jordan Stucky
Is it the heat or the excess moisture that causes to buckle?? I'm thinking no Truckmount because of the HEAT????My 3 vac motor porty w/booster which we will leave out the brand, is NOT heated...Can I do the EVO wand with warm/hot water and 2 of the 01 jetsI got the normal 17 inch 175 with stripping and steel wool pads and sanding screens, The Roots 45 Dual Heat Ex. TM and the 3 Vac Motor Porty NO HEATLookin at about 1500 sq ftJust wants to CLEAN...no sanding..
