Can I rinse an older wood floor with 3 Vac Motor Porty, Glided Evolution/2 jt/01 tips
jstucky
Jordan Stucky
Is it the heat or the excess moisture that causes to buckle?? I'm thinking no Truckmount because of the HEAT????My 3 vac motor porty w/booster which we will leave out the brand, is NOT heated...Can I do the EVO wand with warm/hot water and 2 of the 01 jetsI got the normal 17 inch 175 with stripping and steel wool pads and sanding screens, The Roots 45 Dual Heat Ex. TM and the 3 Vac Motor Porty NO HEATLookin at about 1500 sq ftJust wants to CLEAN...no sanding..
Ed Valentine
Ed Valentine
Jordan;
Why couldn't you rinse using the RECOIL-3 XPS system? My heavens it has way more than enough vacuum on hard floors without question. IMHO, in addition, I don't think you have to worry about the hard floor buckling either from what I see in your picture.
Anyways, hope things are well and say a hello to your dad!
best;
Ed Valentine
cross-american.com
GCCLee
C. Lee
I hope you continue to update this thread w your progress.
More or less this is a you first situation, an I am curious. Been wanting to see this sorta thing for awhile : )
