Can I run 6 hoses on a Dynachem 24hp w/o losing 30% suction
Moser Bros.
I'm cleaning a law office on Friday and I don't want to use a portable.
I have a Dynachem 24hp Honda with a #4 blower, I'm going to scrub with a Cimex prior to extraction, I think I'll lose about 30% suction over 4 hoses, but I'm not sure on how much I'll lose, I'm also using an Airpath fan and post padding with an encap.
You'll be fine.
Since the DC machines only have a single 2" port you don't really have the choice to run a Y, so go with what you got.
Dallas, Texas USA
Moser Bros;
Insure that you are at 16" of lift with the vac inlet sealed. Adjust the vac relief valve if required.
When going over 200', I would try to utilize 2.5" hose.
We have run with 300' of 2", but you must keep the hoses straight & free of foam for maximum lift at the wand.
Larry
SRI Cleaning
West Chester, PA
Anthony Firmani
I think you'll be fine. I have ran that much hose on an 18 horse white magic. You'll tell the difference but it still will be beter than a portable.
