WD-40 will clog hx'ers.
Will a machine with clogged or dirty hx'ers run hot? Yes my
Everest was running hot even with dirty exchangers. Just not as hot as it could.
Try using Pierce. I like it better than wd-40.
I can take a styrofoam cup of water and add a drop of wd-40 and it will just sit on the water.
I can repeat with a drop of pierce and come back later and it will have worked its way through the bottom of the cup.
The whole point of using a penetrating lubricant is to displace any possible moisture in the blower which will usually be on the lowest point of the blower. If you run the blower good with the hose off you will drive out most moisture.
If you have ever sucked foam or water through your blower while cleaning then the hxer will definetely get dirty. I cleaned the hx'ers on my Legend once and plan on doing it again soon.
After you clean them you will notice much better heat because the preheaters will keep the preheated water up to the ideal temperature.
http://www.questchemicalcorp.com/Produc ... cfm?ID=142
